New phone
Beeella
I need a to transfer my phone number to this phone but idk how and I don’t have my other phone
2 REPLIES 2
@Beeella
Are currently with PM?
If you are, just transfer the SIM card to the new phone. Or if it is a eSIM, download the PM app on the new phone and login to your account then purchase a new (free) eSIM.
slusagm
so, you lost your old phone and no more sim card?
buy a Public Mobile sim from Telus or Koodo or MobileKlink, or online via Amazon.  After you got the card, ask PM support to update the card number.  After PM confirmed that is done, then you can insert the card and use it on your new phone
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
