12-30-2023 11:27 PM
Hi there, I want to confirm im eligible for public mobile before i switch from fido.
I have an apple SR
I also want to confirm my number will be able to be ported.
12-31-2023 11:33 AM
You're very welcome @Golhamz12 Glad I could help answer your question. Good luck.
12-30-2023 11:42 PM
Great thanks
12-30-2023 11:40 PM
yes, Apple phones will work on PM
To confirm if you can port your number into PM, please check here:
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
12-30-2023 11:32 PM - edited 12-30-2023 11:33 PM
I think you mean iPhone XR? If so, I have an XR.
And yes, you can port over your number from Fido.
Just make sure you use the PM App to sign up. Here's how.
How to sign up with Public Mobile
