Having issues with porting number
Liamthobbs
I tried to port my number and it told me there was a failure with activation. i think at this point I’d like to get a new number just to make it easier but there’s no easy way to contact support. I sent them a ticket with no response.
1 REPLY 1
@Liamthobbs  I’ll send you the porting team number private message they can give stays update on the port or retrigger it if needed
but to submit ticket you can use this direct link to contact support
send  a  private message   To CS_Agents
