No network
Abbigale
I just became a customer. I set up everything and went through all of the steps last night. I thought my eSIM was fully activated but I have no network no messaging capabilities.. it just says SOS at the top of my screen. I need help, I need my phone to work
Abbigale
Okay! Thank you very much!
@Abbigale  Usually with in the hour they reply but
Abbigale
Thank you for all of your suggestions, I ended up having to message to open a ticket, hopefully they reply in a timely manor
Abbigale
Thank you very much! I have sent a message to them, I hope they reply fast!
@Abbigale  Submit ticket with support . Sounds like maybe the sim need to be re provisioned
send  a  private message   To CS_Agents
@Abbigale
Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
