12-31-2023 10:34 AM
12-31-2023 11:31 AM
Are you @Briar1968?
12-31-2023 10:52 AM
Yes I am activating eSim. The activation seems to have failed during activation, I never made it to install eSim.
12-31-2023 10:50 AM
Time for the customer support agents, @Sunnybo
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
12-31-2023 10:50 AM
did you wait 5 mins before you try to log back in?
if you did wait, then you might need to open ticket with PM support.
And are you activating eSIM? if you are, check your phone's SIM Manager screen or Cellular > Settings and check if Public Mobile eSIM already there, if so, enable it, or enable "Turn on this line" and set it as "Primary" on iPhone
12-31-2023 10:48 AM
Log out did not work.
12-31-2023 10:41 AM
@Sunnybo Submit ticket with support
send a private message To CS_Agents
12-31-2023 10:41 AM - edited 06-27-2024 10:52 PM
try this,
if that does not work, open ticket with PM support. Private message CS Agent at:
12-31-2023 10:40 AM
Here's how to contact an agent @Sunnybo
12-31-2023 10:38 AM
12-31-2023 10:36 AM
