How to change plan to $29 for 10 G
Hannnnnnn
it is showing on the website but when I log in, it doesn't show
17 REPLIES 17
Hannnnnnn
this moring
Andy85
@Hannnnnnn wrote:
my friend's
@Hannnnnnn Would you happen to know at what time your friend changed their subscription? It is possible that Public Mobile has since changed the conditions of the plan. Your friend might've been lucky enough to select the plan before they changed the details! 😀
Hannnnnnn
my friend's
as367
The plan was not listed as "new activations only" until today.  What's the point of this restriction? Not everyone wants 40GB at 5G. I personally, due to ubiquitous wifi, can easily live with just a few GB/mo. This $29 plan, after my loyalty discounts, would be perfect for me. The $25 1GB plan is functionally useless due to how slow it is.
Communication is key!!
Hannnnnnn
it is unfair to other existing users.....
Hannnnnnn
thanks, but the budget doesn't allow me😂
To be honest with you @Hannnnnnn and @GeoffK , as decent as this deal is, I would seriously consider taking the $34 40GB 5G plan over this ANY DAY of the week. $5 more gets you 30GB more data.
https://subscribe.publicmobile.ca/en/mb/activation/plans/40GB-5Gspeed7
Hello @Andy85
Where does it show it's for new customers only? I don't see it.
Hannnnnnn
no, my friend is an existing user, she changed it this morning
GeoffK
i have the same issue as well if i sign in i don't see that deal im tried both my app and website
Andy85
@Hannnnnnn are you a new client or an existing user? The fine print mentions that it is for new activations only.
Hannnnnnn
New Brunswick, my friends changed successfully this morning
Which province are you in?
Hannnnnnn
I did, but it doesn't show for me...
Chalupa_Batman
Hi @Hannnnnnn
Try logging in via the App. It shows there for me.
