How to activate if APP doens't install on my device?
CatalystOne
I've just subscribed and got the confirmation email, BUT it seems the only way to activate is via an Android app that is not compatible with my device?
If I can't activate, I will just cancel the whole thing and trash the useless SIM.
Can't get through to any support either, chat is open, but force-closes my chats. The direct link to CSR fails.
My patience with PM is nearing its end.
Thanks in advance for any constructive assistance!
CatalystOne
I've also heard that but I'm happily chugging along with Windows 10. Anyway I got activated using a second phone.
CatalystOne
I meant such a poorly produced activation process and website. It doesn't take rocket science to figure out they should always have a live toll free number for activation and a website for this.
CatalystOne
Thanks!
I managed to send a message to CSR and submit and submit a ticket. I'm a retired enterprise software engineer and in all my years have never seen such a poorly produced activation system.
Thanks again!
Chalupa_Batman
According to my research and I've never personally tried this although if you do, we'd LOVE to hear your feedback.
https://www.digitaltrends.com/computing/how-to-use-android-apps-in-windows-11/#:~:text=Yes%2C%20you%....
Rumor has it you can run Android apps on Windows 11.
HI @CatalystOne
two ways,
1. easiest is to ask a friend to help.  install on his phone and run via the activation there.  You can still activate esim but have to be very careful, need to stop before the app tries to install on your friend phone
2. you can still use the browser to activtae.  After payment step, you cannot go further.  You will have to ask support agent to finish the rest of the step for you
  To submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
@CatalystOne  Can you use a friends phone to activate then delete app from there  phone .  you can manage the account on the website from there
