How recover old deleted messages when option (1-9) is not available?
MrtGeekDb
How to recover old deleted messages when at the voicemail menu the option (1-9) is not available?
Thank.
10 REPLIES 10
MrtGeekDb
This is what I do but two of them appear to have not been re-saved and are gone 😞
dust2dust
Voicemails stay on for 10 days. You can keep re-saving them to go longer and it will warn you that messages are expiring. But once gone, they're gone.
MrtGeekDb
Dammm... No way to recover them....
@MrtGeekDb wrote:
Not sms or text old voicemail message.
HI @MrtGeekDb   Then sorry, if it is gone, it is gone  😞
MrtGeekDb
Please clarify...are you asking about deleted texts or deleted voicemail messages ?
HI @MrtGeekDb   you meant sms/text?
You are on Android, if you  have setup backup to Google, you can try this
Sign in with your Google Account on a different phone. During device setup, click on 'Restore' when it asks if you want to restore your Android backup. Complete the setup process and check your messages folder
MrtGeekDb
Android 9 version. 3 months old messages maybe.
HI @MrtGeekDb   if the voicemail is deleted, it is deleted.  PM does not keep deleted voicemail.
hairbag1
What kinda phone ?
How old are the messages you wish to retrieve ?
