How long does "refer a friend" reward take to show on My Rewards (old program)
Mechecor
Just referred my dad to PM
Wondering how long it takes for the $1 off/month reward to show up in My Rewards?
I'm part of the old rewards program.
2 REPLIES 2
PM_5G
I found it takes about a week to see referrals show up in My Rewards and within 2 or 3 days your Dad should see his $10 credit - if it does new message customer service - i have found you need to make sure you hit ADD not just cut and paste the referral code into the box - made the mistake once!
@Mechecor  The one that referred shoukd see the $1/1point right away after activation and the referred person should see the $10 credit with in 72 hours after activating
