09-09-2022 09:56 PM
09-09-2022 10:06 PM
You’ll need A valid email address
Your Public Mobile phone number
Register To create a My Account profile you’ll need the help of a Customer Support Agent press Chatbot
or send private message CS_Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
09-09-2022 09:59 PM
@loisl9006 wrote:I need to set up my account
Are you already a customer and am asking about your Self Serve account? If you activated yourself online, the Self Serve account would have already been created. If you activated at a store but never created the account, you will need to ask a customer support agent for help by starting here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If you're not yet a customer, you will need to buy a Public Mobile SIM card. After you have that, you will need a credit card to pay for the plan and you can open a Public Mobile account by going to activate.publicmobile.ca
09-09-2022 09:58 PM
@loisl9006 if you had activated online yourself, you would have setup a Self-Serve My Account already
But if you activated in store and did not setup a My Account login after, just open ticket with PM Support using the "forgot Password" trick:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
