How do I opt out of public points.
dean3
How do I opt out of public points?
12 REPLIES 12
Hi @Handy1 "points forever" is still wrong
Customers can choose not to collect points and not to collect any rewards.   So, they can choose "no points forever" instead.  It is a customers rights to choose to opt out any rewards program offered by any business
Meow
@Handy1 wrote:
@dean3 @You can’t once your in public points your in em for life lol
This is NOT correct. You can opt out of Points but then you have Nothing and cannot get back to Points so you have NO rewards at all.
That much is true, @Handy1
PM is trying (really hard) to cut costs so they've given the 'opt out' option for the lesser reward plan.
I'm sure the suits in the upper offices really like that idea - what's good for them ain't for us customers.
@HALIMACS @hTideGnow  Never considered not wanting the reward of any sort , however that said I just simply meant that the consensus is that rewards vrs points rewards are preferred and once points there no going back it’s just points forever
@dean3  YES,  opt-out is definitely POSSIBLE.  BUT you will not collect any rewards at all , you won't be joining back the old rewards
Quigley
@dean3
Sorry but you can't opt out of the points rewards system and go back to the $$ rewards system. If that is what your asking.
There's no going back, unfortunately.
Untrue,  @Handy1
You can opt out of public points.
Your just can't get into Public rewards.
So best to stay in public points if you're already there.
hi @Handy1 not true, by law, people all have right to opt out rewards system.  And you can message PM support to opt out Public points and not collect any rewards.
  This is consumers rights.  Some people opt out rewards for various reasons like religious
JK8
@dean3
To opt out of Public Points do the following:
Log into the Rewards portal
Choose About Public Points in the tab
Scroll to the bottom and there is the Opt out tab
Edit:
Hi @dean3 opt out from Public Points will not bring you back to old rewards system.   Opt out just mean you are not getting any rewards at all.
if you really want, open ticket with Pm
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Meow
If you opt out of Points you will have Nothing as you cannot get back to $ rewards (if you were there).
