01-11-2022 09:04 PM - last edited on 01-11-2022 09:26 PM by computergeek541
Hello all,
I just purchased a plan with Public, but when I enter the SIM in my old 2016 Samsung S7, I get the "SIM network unlock PIN" message and of course I don't get any service.
I understand that prior to 2017, phones could be locked and that I need to contact the original carrier but I don't remember who it was at all. I could have purchased it at Costco or somewhere else, and I don'r remember who the carrier was. So I'm stuck! If I call Videotron, Bell, and Rogers, will they also help me out even if I had purchased a plan with one of their sub-brands like Virgin, Fido, etc.?
Thanks a lot for your help! @ Moderator_Team1@ Moderator (note to everyone: these usernames of not those of moderators)
02-26-2022 10:05 PM
01-18-2022 08:56 AM
Oops, thanks for that! Obviously my post wasn't the solution, that was a mistake. I'll select a more appropriate post.
01-18-2022 03:26 AM
@tmerlin wrote:Hello all,
@ Moderator_Team1@ Moderator(note to everyone: these usernames of not those of moderators)
Here is a video that I found that actually shows you how to unlock a Samsung S7 phone specifically with any carrier and networks. https://www.youtube.com/watch?v=ugHzVmt4SPo
Hope this helps.
01-15-2022 02:00 AM
Happy to hear you figured it was Fido. It's good to be here!
01-12-2022 04:19 PM
I am happy to hear your memory returned so you could contact fido for the unlocking code. And kudos to the fido rep who supplied you with the code without question or hassle....thats a first!
01-12-2022 02:28 PM - edited 01-12-2022 02:30 PM
@tmerlin Glad to hear that you have it unlocked. I see that you chose your post as the solution, self solutions are frowned upon especially when you had many members helping you and saying to either contact your precious provider that you had service with that phone or to contact Samsun Canada. Those are the posts that solved your issue you just needed to remember who your provider was at that time lol. I have unmarked your solution so that you can give it to the member who helped you out the most
Enjoy your savings with Public Mobile
01-12-2022 02:21 PM
01-12-2022 02:19 PM
Hello all,
Thanks for the great advice, I finally got my phone unlocked this morning just by chatting with Fido who I finally remember being the carrier I was using in 2016. It took a few minutes to chat online with them, very easy.
Best wishes to all who replied!
01-12-2022 06:42 AM
Go to a place like TMS who sells all providers and ask to borrow their active sim cards to determine who's network you are locked to
01-12-2022 01:57 AM
Here is a tutorial on exactly what to say to Samsung Canada live chat when asking for your devices' unlock code.
01-11-2022 10:27 PM
@tmerlin : At the bottom of an earlier reply from computergeek541 was a throw away line saying Samsung may be able to help. They do. They have an excellent chat feature. They can provide you with the unlock code. No need to hunt down the previous provider.
01-11-2022 09:52 PM
Every provider will try to help you but when it's locked to another one there is nothing they can do.
Private message me let me see if I can help you @Technicals
01-11-2022 09:38 PM - edited 01-11-2022 09:50 PM
@tmerlin wrote:Thank you both, @computergeek541 and @HALIMACS for the prompt response!
So... if I go to:
- About phone
- Status
- SIM card status
- Network says "Videotron", does this mean it is the last carrier registered on the phone?
I checked About phone / Software information, it does not give a hint on the carrier, or at least it's not understandable by me.
I don't own SIM cards from all carriers but I guess I will start with Videotron and also Samsung Canada.
I'm trying to point you toward an entry called something simialr to "Service provider SW ver.". There will be a string of 3 character codes at the end of that. Videotron in the SIM status only refers to the network that you're currently connected to. It isn't related to the lock status of the phone.
01-11-2022 09:29 PM
Thanks! But it looks like that site only searches for US carriers.
I might go with the shop option if I'm still stuck tomorrow.
Thanks again.
01-11-2022 09:28 PM
Thanks, yes I may have contracted with Videotron or one of their sub-brands, I'll call them tomorrow but I don't expect much help from them 🙂
I tried your link and luckily it isn't blacklisted. Thanks!
01-11-2022 09:23 PM - edited 01-11-2022 09:24 PM
Yes @tmerlin , start there. Do you recall having service with them?
And remember, all Canadian carriers are required, by law, to unlock devices with no charge to you.
If they TRY to suggest there is a charge, tell them you'll contact the telecom regulator.
Also, you may wish to check this to be sure the device isn't blacklisted... Check the Status of Your Device in Canada | DeviceCheck.ca
01-11-2022 09:21 PM - edited 01-11-2022 09:22 PM
try to call to manufacturer of your device brand give them the IMEI number dial *#06# for your device them know which carrier was .... or try eBay, lower cost.
01-11-2022 09:20 PM
So... if I go to:
Thanks again for your help, and best wishes for 2022!
01-11-2022 09:15 PM - edited 01-11-2022 09:18 PM
Try this website to find out who was the original carrier that can unlock your phone:
https://www.imei.info/carriers/canada/
You will need to enter the IMEI number by going to Settings>About phone.
You can also go to a local cell repair shop that offers unlocking service.
01-11-2022 09:12 PM - edited 01-11-2022 09:26 PM
@ Moderator_Team1 @ Moderator
Please note that those usernames that you have tagged are not of Public Mobile staff or customer support agents. Also, note that Public Mobile cannot assist you in unlock a device locked to another carrier.
One way to find out who the original carrier is to insert SIM cards from different carriers until you find out which one doesn't make the phone prompt you for the SIM network unlock PIN.
I would also suggest to go into the phone's About menu and look for the the software version information. There shoudl be an be an entry that refers to a service provider's software version. While this doesn't eman tthat someone couldn't have changed the device's installed software, this entry will generally provide a very good clue of which carrier the phone is locked to.
Samsung Canada may be able to assist you.
01-11-2022 09:10 PM - edited 01-11-2022 09:16 PM
Does the device still have the old SIM in it?
Is the carrier stamped on the SIM?
You might also want to check the device's network connections tab. It may display the most recent carrier which may assist in this regard.
EDIT: Also, perhaps this may assist? (can't say i've tried it, though, so use at own risk...)
