How do I get my old username back?
_sal_
Is this even possible anymore?  Whenever I log in it logs me in with a new username even though my original account is associated with another username in the community forum.  I wish there was a way to merge the posts together.
Does anyone know?
sivaprakash1234
Support can assist with an easy fix for those experiencing similar issues, as many others have successfully regained their old community ID through their help.
HI @_sal_
we saw this a lot and most of them get their old id back without troubles
@_sal_  Support will be able to help easy fix for them many had this same issues and got old community ID back
_sal_
I don't remember, it was before the website was upgraded.  After the upgrade it forced me to create a new username, I could not use my original one.  Now there are two of me on this community with separate post history (one which I can no longer log in as). I messaged the CSAgent so I'll see if they can fix it.
HI @_sal_
when was the last time you were able to use the old username?
most likely you can get it back, but check with support agent.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  (Login with your current email login ) Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
@_sal_  Sounds like ever safe has issues linking your account . Contact support they can help you to get your old community ID back
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agents
