07-04-2019 05:40 PM - edited 01-05-2022 05:43 AM
07-04-2019 06:14 PM - edited 07-04-2019 06:15 PM
An easy way is to reset network settings on your phone. Something from your previous provider may've been stuck. Be sure to check Self Serve and see what plan/data allotment shows up, just to rule out the obvious.
07-04-2019 05:45 PM - edited 07-04-2019 05:51 PM
You most likely need to either hit the toggle switch in your settings or configure your APN.
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
