How do I get an update on ticket 263102-958
Reyk
Reyk
thanks.... just a little unfamiliar with the system,,,appreciate the response
@Reyk @To get a ticket started
Getting help from agent
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
HALIMACS
@Reyk
Contact a Customer Support Agent, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
Quigley
@Reyk
Send a private message to CS_Agent
And ask about your ticket.
