08-08-2024 03:05 PM
Hi,
I'm a new subscriber to Public Mobile and having trouble getting my service to work correctly. I have used the chat bot and submitted tickets, but the support agents have been unable or unwilling to help me solve my problem.
Now I'm paying for a service I can't use and I can't seem to get someone to actually help me fix it. Anyone out there able to suggest a solution for getting actual customer service from Public Mobile?
Thanks!
Service
08-10-2024 02:57 PM
08-09-2024 01:24 PM
Hi @computergeek541 , thanks for your post. I've always had good luck with Lineage OS in the past. It's mostly just a repackaging and enhancement of the stock open source Android, so in general, few if any compatibility problems.
I just spoke to a friend that he's had an issue using an eSIM on a stock phone before, so it's something that could just be related to this new-ish technology. Of course, a compatibility issue with my version of Lineage can't be ruled out, although the Pixel 7 Pro is explicitly supported and tested by the Lineage project, so one would expect compatibility to be good. In other words, eSIMs would be known to be working in general. Anyway, impossible to know the real root cause without further research. One would expect a good tech support organization to have experience with such things, but this doesn't seem to be the case with PM, unfortunately.
Ultimately, the solution of going to a physical SIM card actually works better for me because I have another older phone that doesn't support eSIMs that I may also want switch to from time to time.
08-09-2024 12:11 AM
@EdH wrote:I have a new Public Mobile service with eSIM card in my Pixel 7 Pro running Lineage OS 21 (Android 14). More details in my previous post below.
There shouldn't be any changes required to the APN settings to make data work on this device at Public Mobile. Since you're familiar with custom ROMs, I would suggest instock stock Google ROM for your Pixel 7 Pro as I do know for sure that this will work 100% without needing to make any APN setting changes (assuming that the Public Mobile service is working properly). Please be aware of that there are risks of changing ROMs which could result in the "breaking" of the device if not done correctly.
08-08-2024 11:36 PM
So, I finally broke down and got a physical SIM card, transferred my service to that card using the PM app and deactivated the eSIM. Now everything is working fine. Never was able to figure out why the phone wouldn't connect to the mobile internet using the eSIM card.
I must say, however, that my experience with PM customer support was absolutely abysmal. I thought it would be hard for customer service from large corporate entities to get any worse, but Public Mobile (and by extension, Telus) have managed push the bar even lower.
The CS agent, Alex, didn't want to spend any time or effort actually helping me troubleshoot the device. Kept blaming the user, the device, the fact that they can't "see" the device settings, anything possible to avoid having to work with me to actually try to find a solution. The agent didn't come across as very technically skilled or knowledgeable at all. It was a big waste of time.
The total lack of any kind of phone support even when a new customer is with a non-working device is a huge black mark on this company. Here, in the community forum, I at least got the impression that people really wanted to help. I'm thankful for all of your suggestions, even if none helped to solve the original problem.
08-08-2024 10:07 PM
I gave instructions on the post by @softech that you linked a try, but to no avail. I had also already thought of the idea of completely deleting the APN and recreating it as they suggest. Sadly that didn't work either. Thank you very much for the suggestion, though.
08-08-2024 06:41 PM - edited 08-08-2024 06:43 PM
@EdH Too bad. I'm not sure if this link will work, but hopefully it takes you to a post by @softech on the topic of APN settings that could be worth a try if you haven't already done it this way. (Edit it sort of worked, but instead of going straight to the post you have to scroll down a bit):
https://productioncommunity.publicmobile.ca/t5/Get-Support/apn-settings/td-p/1169501
Only other thing I can think of is to check if there is a carrier services update for your phone.
08-08-2024 05:38 PM
Sorry, setting the APN to SP.MB.COM (all caps) didn't work. 😞
08-08-2024 05:15 PM
@EdH Try making the first line of the APN settings in all caps and then reboot, that is SP.MB.COM . May not help for a Pixel but for some reason OnePlus phones need that line in all caps so might be worth a try.
08-08-2024 04:36 PM
08-08-2024 04:32 PM
hi @EdH what phone brand and model you have??
08-08-2024 04:22 PM
Yes, I had already found that link and went through those instructions to redo the APN settings and reboot the phone. No change in behavior. I can make and receives calls and texts, but the cellular internet won't connect.
By the way, the customer service agent handling my ticket didn't even mention this possibility.
08-08-2024 04:18 PM
@EdH Have you checked the APN settings?
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
08-08-2024 04:03 PM
Basically, I have a new Public Mobile service with eSIM card in my Pixel 7 Pro running Lineage OS 21 (Android 14). There was initially a problem getting my old phone number transferred, but that has been resolved.
My problem now is that the phone will not connect to the mobile internet network. It says "No connection" for the mobile network in the internet settings of my phone, although there is no '!' in the signal strength indicator which usually shows when there is a cellular network connection with no internet. Sending and receiving calls and SMS messages is working, however.
I am currently in the greater Montreal area and thus not roaming or in an area where internet coverage might not be available. The customer agent said something about setting the eSIM as the "primary" SIM card, but I see no way to do that in my phone's settings. There is no other SIM card in the phone, so the eSIM must be primary one by default. No other SIM card is shown in the settings.
This must be some kind of network configuration setting error that I can't find, or an actual mobile internet service outage for PM in this area. The customer agent claims there is no problem on their end, but clearly he couldn't even be bothered to check for potential outages because he didn't even ask where I was located.
Anyway, thanks for the offer of help. If anyone has any clues, I'd be happy to hear them!
-Ed
08-08-2024 03:45 PM
@EdH Can you explain the problem here in case we can help (but don't include any personal information as this web page is public).
08-08-2024 03:16 PM
I have already submitted at ticket. The customer agent, Alex, is not being very helpful at all. Basically just gives boiler plate responses without offering to help with any actual troubleshooting. I have asked for an escalation and he doesn't want to give one. I had a working phone before moving to Public Mobile and now I don't. This is no way at all to treat a brand new customer.
08-08-2024 03:13 PM
hi @EdH get actual PM staff to help by submit ticket first
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
