11-24-2023 11:33 PM - last edited on 11-24-2023 11:35 PM by computergeek541
I have a Zoomer number, but Zoomer isn't listed on the list of providers to port from. What do I do without messing things up?
Also, I subbed to the 20GB $34 5G plan last week. Before I activate my SIM, is there anyone I can talk to to change this to the upgraded plan? Seems silly to activate on the old plan now.
08-10-2024 01:57 PM
I called Zoomer and they confirmed: Choose Cityfone and add two zeroes to the front of your Zoomer Wireless account number.
11-25-2023 04:10 PM
Yes I did as there was that message that told me to add the two leading zeroes. I really wish that I could speak with someone directly about this as I am not sure what the status is or what the issue could be. I'm hoping that there is a way that I can get a hold of someone live to address this 😔
11-25-2023 04:07 PM
Sounds like you need support. When you entered your Zoomer info, did you ensure that you put two zeroes in front of your seven digit account number?
11-25-2023 04:05 PM
Glad to hear your port went well! What is happening to mine? I'm actually starting to get worried 😟
11-25-2023 03:58 PM
My port from Cityfone (Zoomer) went smoothly and took about 10 minutes. Zoomer hasn't closed my account, but I suspect that will take a few more days.
Now I just need to figure out how to change my plan from 20GB to 40GB without bonking things up.
11-25-2023 03:23 PM
Hi softech,
I since have been able to get my PM SIM activated and have an active PM number. I attempted to transfer my number over but it said the number is not portable. I have reached out to CS_Agent and they said that the port is in progress and that I should receive a text from Zoomer. It has been about 4 hours now and I didnt receive a text or anything and currently I still have both my new PM number as well as my existing Zoomer number active. I'm guessing things are just slow? Any other advice to give to me? 😊
11-25-2023 12:41 PM
Do I need to delay my activation until I hear back from the CS Agent, or can I proceed with activating and hope they make the change after activation?
11-25-2023 10:02 AM
I got to the point where it was trying to activate my plan but it never passed that point
11-25-2023 12:30 AM
@domo_shark wrote:I did and unfortunately it still failed. Based on this chain, looks like I just have to send a message to CS_Agent, which I did so hopefully I'll just hear back from someone 😊
@domo_shark was the account setup and activated yet? can you make outgoing calls with your PM sim card or PM esim?
11-25-2023 12:29 AM
11-25-2023 12:25 AM
@domo_shark have you submit your porting request yet? You selected Cityfone?
11-25-2023 12:23 AM
I am in the exact same boat
11-24-2023 11:40 PM
Wow guys - received two helpful answers in like 3 minutes! Thank you!
11-24-2023 11:38 PM
@Boxcar0434 wrote:I have a Zoomer number, but Zoomer isn't listed on the list of providers to port from. What do I do without messing things up?
When it comes to the plan, you could pre-schedule a plan change to happen at the time of your next renewal. To discuss this an the number porting with a Public Mobile customer support agent and to discuss if anything can be done for the plan, please send a pirvate message to CS_Agent. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-24-2023 11:37 PM
Please choose Cityfone
and you can check , more info here
