Service transfer issue
Discordo82
I just transferred to Public from my old provider, but i used an old account number when making the transfer. I can make outgoing calls, but texts or incoming calls do not work.
Any help is appreciated, Thanks
Discordo82
Thanks for your help!! 👍
Then it sounds like the port didn't go through.
There is a number you can call to get this porting issue resolved. I will send you a private message to your mailbox in the top right corner of this page or click on this link to direct access.
Discordo82
Got the text from old provider and responded to allow the transfer.
old sim still says the provider name.
Chalupa_Batman
Hello @Discordo82
Did you get a text from your old service provider? If so, did you say yes within 90 minutes?
If you put your old service providers SIM card into your phone, do you still have service or does it say SOS.
Confirm these for me and if things still aren't working, I can send you a number to call to assist with the porting process.
