03-22-2024
11:29 PM
03-24-2024
01:02 AM
computergeek541
I'm having trouble downloading images in my text messages or messages does anybody know the APN settings or if they changed?
I remember seeing something about APN changes.
03-22-2024 11:58 PM
the new APN settings worked but all caps thanks
03-22-2024 11:52 PM
@Joe_Crushy issue like this is more a problem on the iPhone side, you have to ask your friend to enable Send Text Message on his iMessage settings. If still fail to send, he can press and hold on the message to bring up the menu and select Send as MMS
03-22-2024 11:45 PM
I change the settings but I still can't download from a certain user with an iPhone, other people from Android I can get images no problem text message is it something and the person's iPhone settings that they can't send it or is it me that I can't receive it from an Apple device
03-22-2024 11:33 PM
for some phones, there might be a bit more work then simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
03-22-2024 11:30 PM
@Joe_Crushy - Manually configure your phone to this (Only Android - for iPhone reset network settings or update iPhone)
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
