09-20-2023 08:31 PM
09-20-2023 09:46 PM
you have been posting the same question again.
As explained earlier, only PM support can help with providing sim card PUK.
I understand you are unable to get the verification code, please try to click "Didn't receive code?" at the 2FA screen and then click "Send email" to have the code send to email and see if it works.
If not, simply reply the message PM support sent you and let them know. Again, they are the one with your sim PUK and you need to work with them for the PUK code
09-20-2023 09:17 PM
unfortunately sim card unlocked code can be provided by PM support only, so you have to work with them for a solution. Let them know you have trouble with the verification code.
(but also, in the verification code screen, click "Didn't receive code?" and then click "Send email" to have the code send to email and see if it works)
09-20-2023 09:14 PM
I've messaged support. Not very helpful. They're asking me to sign in. When I do do so, they send a verification code to the same phone number. But it's locked and I cannot access.
09-20-2023 09:09 PM
@Ebou2 do you get the same PUK error if you insert your PM sim in another phone?
If so, then it confirms it is a sim card issue, please follow this to open ticket with PM support:
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM Card, SIM cannot be accessed" or on an iPhone's status bar showing "Locked SIM"
open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
09-20-2023 09:07 PM
The phone is a Samsung S22 ultra. Other sim cards are working. P M sim is locked, and is asking for a PUK code
09-20-2023 09:02 PM - edited 09-20-2023 09:08 PM
@Ebou2 wrote:
- My sim card is locked. How do I get the PUK code
@Ebou2 , Please see your 1st post ‘ How do I find my PUK number ’ that you created regarding this issue! You were answered on that post where @softech answered you!
Edit: New post was removed right after I typed this! Sorry!
09-20-2023 08:33 PM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
call Samsung 1-800-726-7864 for a master unlock code.
The only info you will need to provide is the IMEI and where the phone was purchased
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
09-20-2023 08:33 PM
Yea
