How do I do this?
Takaya
I would like to be transferred to the $29 subscription with 20gb please.  I am going to close mine and my husbands account if they refuse.
Sansan
Good luck. I think threats more work at Bell and Rogers
@Takaya
Only for new members (activation) only.
Dunkman
@Takaya
Which plan are you on presently?  If you are on the $15 or $25 plan, there is a higher possibility that a customer service agent may change plans for you. YMMV. No guarantees. If you are on a higher priced plans, it is unlikely that a CSA will change.
hi @Takaya
that is a plan for new activation only.
Yes, some asked and got it, but also some asked and got declined.  You can try to check with CS agent but there is no guarantee.  please submit a ticket with CS Agent here:
