How do I change my plan
DeniseL
Hi, How do I change my plan, I went to plans and add-ons but it didn't have any new plans just that I could increase/decrease by a GIG
@DeniseL
To change plan sign into my Account and go to plan add-ons tab and use yellow arrow to scroll thru 3G and 4G plans .
Once you find plan you want be sure to change on renewal date . So you don’t lose out on current cycle
@DeniseL
first make sure you use Incognito mode to login My Account, without that, it might not load all plans sometimes
When you are there, to to  Plan and Add-on page, just click Change my plan. Select 3G or 4G speed plan and use the yellow arrows to scroll up and down for plans
https://selfserve.publicmobile.ca/en/account/plan/change-planhttps://selfserve.publicmobile.ca/en/account/plan/change-plan
A reminder, make sure you understand the difference between Change plan now or Change plan on renewal date.  Most people select Change plan on renewal date to save money
@DeniseL  Sign into self serve and go to plan add on tab and search thru available plans
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
adding be sure to change on next renewal and not change immediately there no pro rating for unused data and mins
