How to access my account
Luba1
@Luba1
If you have been in nonpay/suspended status for over 90 days, or ported your Public Mobile number to another provider, then you lost your Public Mobile account, phone number, and access to My Account.
Have you ever created a My Account before? If not and you are a current customer (have been active within 90 days and have not ported out to another provider), you can submit a ticket here to: Create or forgot My Account email or password link
@Luba1
Did you activated your SIM yourself or at a retailer?
@Luba1 login via  https://selfserve.publicmobile.ca
The username is the email address.  If you foegotten that,
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
