08-28-2019 04:52 PM - edited 01-05-2022 06:42 AM
On my last trip to the us I could not use my us roaming because my phone was not set up for it. I received instructions 4days later after contacting the community. How do I avoid the same issue as no instructions are providing with the add. I thought my phone would automatically work once I entered the us. Please provide instructions prior to my departure.
08-28-2019 05:05 PM
Give this a read through. It's from the Knowledge Base.
Hopefully it has everything you need.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/U-S-Roaming/ta-p/307883
08-28-2019 05:05 PM
Normally, it is automatic for most situations.
Here is a good review article on US roaming:
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
A few hints:
Make sure to turn on international and data roaming.
Reboot phone if not work
Toggle airplane mode on, wait a few minutes and then toggle off
Manually choose either AT&T or T mobile as US carrier
