How can I tell what plan I'm on
MarkusB
How can I tell what plan I'm on and what the plan details are.
Ie unlimited data, can/us, etc.
Chalupa_Batman
Hey @MarkusB
Log into your account and go to Subscriptions and Addons
At the top it tells you what plan you are on.
JRod
@MarkusB
When you login to your account on the self serve portal, go to the subscription and add-on’s tab. When you are there it should display all of your included plan details like so:
HI @MarkusB
you can login to My Account, check the Subscription & add-on page and it will give  you the plan details
But generally, Canada/US plan has no unlimited data.  Unlimited data is only for 5G plan
How much you paying now?
Payment history will also tell you which plan you got
