Transfer problem
TianZ
I have registered today with eSim but it looks not working after 5 hours, I lost all the network, can’t make any phone call or text messages. Anybody can help me with this problem?
2 REPLIES 2
TianZ
thank you @softech, followed the instruction to remove the exiting physical sim card from the phone first,  then set the Public Mobile as the primary line,  ALL done!
@TianZ
if you cannot even make outgoing calls,  It sounds to me like a eSIM problem rather than porting.  So, let's help to get the eSIM running first.
First, please confirm if you see the eSIM installed and setup on your phone, use the SIM Manager to check.  And check if the phone connects to PM network at all.
If it was it installed, did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step),  try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone , disable those non PM sim (eSIM/Physica sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
