10-16-2023
03:35 PM
10-16-2023
05:34 PM
computergeek541
Hi Sir,
From my iPhone Outgoing call 1 (647) 580-4001 Oct. 07, 06, 2023 11:02 am and 2:45 pm.
This is not my phone number. Could you please check this number for me?
Thank you
10-16-2023 03:39 PM
the 1 (647) 580-4001 is just a voicemail number. When people call you and got routed to VM or when you call your VM to check message, they will both show on your Usage history. No need to worry about it. This is normal
10-16-2023 03:39 PM
That's a voicemail system number. When you press and hold the 1 key it likely dials that number. When someone calls you and it ends up going to voicemail, that's the call forwarding system forwarding that call to the voicemail system.
