Porting Status
Pkrobin
Hi, I cannot submit a support ticket for some reason. Please check on my number porting status, it has been 20 hrs since Fido confirmed by SMS it was underway. Thanks
Pkrobin
Thanks, it resolved itself a couple hours after I posted this. I had already rebooted and followed the other troubleshooting steps so I guess mine was just slow to change over. Thanks!
HI @Pkrobin you are porting  from Fido?
PM porting support team can confirm the porting status.  I have sent you the porting support team number.  Please check your Community inbox (envelope on top right), check for the number and call
Chalupa_Batman
Hello @Pkrobin
Have you rebooted your phone? Does your Fido SIM card still work? If so, then the port hasn't fully gone through and I can send you a number to call to get assistance. But try those other things first before we send it.
