10-30-2024 02:50 PM
Hi there,
Given the shut down of 3G/HSPA networking in the US, will our 4G plans work?
There's a 4G Plan available with PM right now, 65GB Canada & US for $34 on a 90 day sub... so that's why I'm asking.
Thank you
Service
10-30-2024 03:18 PM
@Chris_ Yes 4G is different and no worries about it going anywheres anytime soon
10-30-2024 03:15 PM
OK.... I thought 4G was HSPA... so that had me confused. They're not the same then, right?
We're not in danger of them shutting down 4G networking anytime in next few years, are we? Lol
10-30-2024 03:07 PM
@Chris_ On the 90 day plan you have to pay $102 upfront with 195GB to use over 90 days . It’s attractive offer for sure and yes it will work in the U.S. best to have phone set to 4G/LTE while roaming in the U.S. anyways and not 5G for easier connectivity
10-30-2024 02:53 PM - edited 10-30-2024 02:54 PM
@Chris_ wrote:Hi there,
Thank you
Hey @Chris_
Of course. 100% will work. As long as you have a VoLTE approved phone that Public Mobile allows, you'll be just fine. HERE is the list. When I went to the US, I went into my network settings and turned off automatic and chose T-Mobile. Then I made sure data roaming was turned on then I rebooted my phone. From there everything worked perfectly. There were some times I used AT&T but very rarely. Which phone do you have?
