02-16-2023 04:32 PM
I lost my phone. I bought a new SIM card from Public Mobile. How can I get my old number on the new SIM card?
02-16-2023 05:40 PM
Whatever you do, @chantalniragira , don't activate the card using the activation portal as that'll create a whole new account and you won't be able to move your existing account/number over to it that way.
Did you do that? Hoping not...
02-16-2023 04:37 PM
hi @chantalniragira as long as your account is active, you can update your sim card on My Account.
Login My Account using a computer and go to Profile page, your can update your sim card there to the new one you got
02-16-2023 04:37 PM
@chantalniragira Sign into self serve in a computer and do. SIM swap
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
02-16-2023 04:36 PM
@chantalniragira Use incognito/private mode to login your account and select either Quick Links or Profile and you can update and change to the new SIM. Your old number will be registered to the new SIM card after verifying with 2FA. You might also need to reboot after completing the SIM change.
02-16-2023 04:35 PM
@chantalniragira yiu can easily complete it yourself at My Account
Login to My Account using a desktop or Laptop ONLY ( do not use mobile phone)
Once Login, click Quixk Links on top right, then select Change Sim card and follow the steps to complete adding the new sim card to your account to tie with your phone number
