01-07-2020 09:46 PM - edited 01-05-2022 08:56 AM
When some one call my public mobile phone, how can I forward this incoming phone to another phone number when I need to do so?
Thanks a lot.
05-23-2020 09:31 PM - edited 05-23-2020 09:33 PM
The current $15 100 minutes plan does not deduct minutes for forwarding calls. The previous version apparently did. You can even still forward your calls when you have consumed all of your outgoing minutes.
Ya that's correct I am currently using it
01-08-2020 09:37 AM - edited 01-08-2020 09:39 AM
@Anonymous wrote:Doing that with the old $10 plan does use minutes (no minutes with conditionals). I would suggest that this is unofficial for the $15 plan.
At least the current $15 plan is consistent with my experience with cell service since the 90's -- forwarding being a traditional airtime saving mechanism.
01-08-2020 09:32 AM
@Nezgar wrote:
@computergeek541 wrote:Forwarding calls does use mintutes on the current version of the $15 plan. Once a call is forwarded, the carrier no longer considers it as an incoming call. The forwarded call is then considered to be an outgoing call.
Are you sure you're on the current $15 plan? Here is what an "unconditional" forwarded call looks like in my usage history:
My Plan
- $15 per 30 Days
Before the unconditional forwarded call:
My Data & Add-Ons Amount Used 100 Minutes Canada-Wide Talk 3 / 100 MIN
After the unconditional forwarded call:
My Data & Add-Ons Amount Used 100 Minutes Canada-Wide Talk3 / 100 MIN
No minutes consumed.And looking at the usage history detail:
Date/Time Call Type Originating # Destination # Originating Location Destination Location Duration Data Usage Usage Type Charge 08/01/2020 9:13 Outgoing Call [My Cel #] [Forwarding Target #] All SK 0:02:57 Minutes $0.00
01-08-2020 09:28 AM
My Plan
My Data & Add-Ons | Amount Used |
100 Minutes Canada-Wide Talk | 3 / 100 MIN |
Date/Time | Call Type | Originating # | Destination # | Originating Location | Destination Location | Duration | Data Usage | Usage Type | Charge |
08/01/2020 9:13 | Outgoing Call | [My Cel #] | [Forwarding Target #] | All | SK | 0:02:57 | Minutes | $0.00 |
01-08-2020 04:29 AM - edited 01-08-2020 04:30 AM
@Nezgar wrote:
@Jb456 wrote:
Ensure you have an unlimited plan as it would count towards your minutes if you're on for example $15 100 minutes. Also ensure you're forwarding to a Canadian number.
01-08-2020 12:33 AM - edited 01-08-2020 12:34 AM
01-07-2020 10:14 PM
@george200911 All the information you will need can be found here:
https://www.publicmobile.ca/en/bc/get-help/articles/call-forwarding
01-07-2020 09:51 PM - edited 01-07-2020 09:53 PM
Android
iPhone
Ensure you have an unlimited plan as it would count towards your minutes if you're on foxample $15 100 minutes. Also ensure you're forwarding to a Canadian number.
Also you can't forward text messages.
