How can I change my number back to what I had.
06-24-2019 01:50 PM - edited 01-05-2022 08:09 AM
06-25-2019 12:49 PM
If the number was assigned by a Telus company first, then the number might be retrievable, via the Moderators. If the number was originally from another provider, it will return to the designated provider's pool as suggested above for a period of 90-days until it is available for usage again.
06-25-2019 07:02 AM
It can't get assigned (barring system errors of course)
A Mod could always manually assign it earlier
And this is only true if it was a Public number
If ported in noone else could ever get the number
@geopublic wrote:@kav2001c Are you sure about that? Are you saying that if I change my PM number to another PM number that number doesn't get re-assigned for 90 days?
06-24-2019 05:47 PM
OK, thanks everyone for all the help.
06-24-2019 05:19 PM
If you want to reach the Moderators, just click on the little envelope at the right of the little bell, upright on the page...
or you may use:
06-24-2019 05:04 PM
@hugfro wrote:I changed it a couple of hours ago, but now I want to change it back. But it wont accept my old number back.
Basically no, you cannot.
Call your old number; if someone answers then guaranteed you cannot have it back.
Otherwise I have no idea whether the moderators can, or will even try to, get your old number back.
06-24-2019 04:59 PM
This is not something that you can do yourself. You would have to ask moderators as suggested earlier, but this isn't something that anyone would promise.
06-24-2019 03:55 PM
@kav2001c wrote:Number is normally in aging pool for 90 days
So 2 options
Wait and then try to change back later (if you enter the exact digits you often can snag the original number*)
Ask Mod to assist
*edit - you WON'T be able to reselect number if number was a port, in that scenario Mod is only choice
06-24-2019 03:50 PM
@kav2001c wrote:False
Number can not be reassigned that quick (90 days normally) so very unlikely a new sub gets the number first
Mod is best one to ask
@geopublic wrote:
@TheOldVR wrote:
Could a MOD help get an old number back?
Judging by the extremely long moderator response times I don't think it's a good idea to trouble them with these kind of issues. If it's going to take 3-5 days to get a moderator response then it will be highly unlikely that number will be available anyway.
@kav2001c You are assuming the OP ported in. I was referring from one PM number to another. The OPs chances of getting that old PM number back are slim to none.
06-24-2019 03:44 PM
False
06-24-2019 03:43 PM - edited 06-24-2019 03:45 PM
So 2 options
Ask Mod to assist
06-24-2019 02:26 PM
Unfortunately, as others have already said, you won't be able to make another number change for another month, plus if you ported your number from another carrier, then your number has been assigned back to the original issuer of your number since your change. There's an outside chance for you to talk to your previous provider and see if they have any suggestions, but most likely you'll just have to go with your current number now.
06-24-2019 02:15 PM
06-24-2019 02:09 PM
06-24-2019 01:58 PM
06-24-2019 01:55 PM
06-24-2019 01:54 PM
@hugfro What do you mean exactly? Phone number from which company? If this number is inactive it would be very difficult to have it
06-24-2019 01:53 PM - edited 06-24-2019 02:15 PM
Is there a reason why you want/need to change your phone# back to the original phone# ?
You could try contacting a moderator to see if it is possible to change it back.
Moderator can be reached at
06-24-2019 01:52 PM
@hugfro You need to provide more details so that we might be able to help you. Is this a new activation?
