Hey team unlocked phone from koodo not working
LancerLeads
Hey team,
Unlocked phone from koodo, SIM for public is activated but still says "No Service" top left in the iphone no matter what I do. Any help would be great!
33 REPLIES 33
@LancerLeads wrote:
pics removed, just checked as well and the IMEI is not on the blacklist
@LancerLeads
The pictures are still there. Please delete them from your Community account profile.
popping
@esjliv wrote:
@LancerLeads
Well, if your phone is fully updated and a network reset has been done, and not blacklisted.
Submit a ticket by methods @softech posted.
But in the meantime, reboot and toggle airplane mode.
You could also try removing the SIM card, and lightly clean the contacts of the SIM, as well as lightly blow inside SIM slot area.
You need to update the provider file on your iPhone after provider change.  Connect your iPhone to iTune running on a PC.
@LancerLeads wrote:
It looks like the number you guys gave me when I signed up already belonged to someone haha
I think the person working the ticket is looking at getting me a new number. I'll keep you folks posted.
@LancerLeads
Oh gosh. This has happened on occasion.
When you call that number, someone picks up?
A number change should get you back on track. Glad this seemed to be attacked quickly.
.. so, you opened ticket with CSA and they replied already?  glad it is heading to the right direction ..
LancerLeads
@LancerLeads
While the community helps you troubleshoot your phone make sure you have reached out for support from the CSA's as this is still pointing towards only partial provisioning of your SIM card.Put "sim not provisioned upon activation" and "human" and follow the prompts to submit your ticket via Simple--Simon the chat bot.
Once you get your SIM provisioned you will need a carrier update. This thread is helpful for all iPhone users when switching providers. @LurganIeUk , @AE_Collector  and the threads author @CalgaryBen  among others can help advise you when it comes to your phone.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323118
@LancerLeads
@LancerLeads
so that device koodo is your phone or you buy it , and do you try your PM SIM card in aonther device is working !!
LancerLeads
@LancerLeads I don't want to freak you out.
But PLEASE PLEASE remove that post with your IMEI and the other post with your name, email, and any personal info.
Fraudsters out there can use this info. in a very bad way.
LancerLeads
edited
@LancerLeads wrote:
Phone is 12.5.4 which I believe is up to date.
I am in oakville ontario, iPhone 6
@LancerLeads
Okay, usable phone here, and an area that is serviable - that's good.
Did you confirm the IMEI is not on the blacklist? Just to rule that out.
Toggle into AIRPLANE mode, leave it there for a minute, then toggle back to regular mode.
Any change?
Still connect to a computer and launch iTune, (with your PM SIM inside),  it will catch up the update if available .. as well, it will download the Carrier Profile
 @LancerLeads : Connect to wifi then Settings / General / About. See what if anything happens.
Twopennybuffalo
Two things to point out.
1. where is the phone from and was contract paid off with new tab structure at all carriers they can “temp blacklist devices if used on another carrier”
2. Can you try another sim from another company perhaps a friends sim and if it read that one it is possible you have a defective provisioning. That is a backend provision from PM that they would have to resend.
LancerLeads
@LancerLeads wrote:
the phone acknowledges that I'm with public mobile, it just says "no service" top left and has yet to prompt me to set anything up. Taken the sim in and out three times now
@LancerLeads
1-What model phone do you have?
2-What city are you in (if you don't mind sharing...)
If Manitoba, there are areas known to not have certain services:
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Text-From-PM-About-Changes-To-Mani...
Here is a link for a coverage map.
https://www.publicmobile.ca/en/bc/coverage
Canadian Cell Towers
http://www.ertyu.org/steven_nikkel/cancellsites.html
Check for outages in your area: https://www.telus.com/en/on/outages
or https://downdetector.ca/status/telus/map/
 @LancerLeads : Did you check for updates as suggested earlier?
LancerLeads
LancerLeads
now my other phone is messed up by removing its original sim lmao this is crazy
 @LancerLeads : I don't know if this applies to phones from the same family (Telus) but did you connect the phone via USB to a computer running itunes and check for any updates.
@LancerLeads wrote:
activated myself online with no problems, chose a new number and put in my $25 voucher. I've turned the phone off and on twice now and taken the sim card out once as well.
I guess you did everything correctly and tried all the possible fix.  There seems to be some provision issue late.  I suggest you to open ticket with PM CS Agent:
(After you open a ticket with CSA, please monitor your Community inbox, envelope on the top right.  CSA will communicate with you via messaging within Community)
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot. Start with typing "Submit a ticket", click on "Contact Us", click on "Other" from the choices, click "Click here to submit a ticket" then Follow the prompts to submit a ticket.
2. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@LancerLeads ,
Perform a reset of your Network Settings.
Also, what model phone do you have?
There have been occasions that activations just take a bit of time, after various reboots; although it really should be immediate.
@LancerLeads
can you check the SIM card is properly is right,
Cool.. so, the top of the screen simply say No Service?   Try reboot it once more.
Also , if you have a second phone around, unlocked phone, try to put your PM SIM into it and see if it works
LancerLeads
@LancerLeads
I recommend editing that screen shot to block out or remove personal info.
This is a public forum.
To edit it, hit the 3 dots at top, right of your post.
LancerLeads
hey there, brand new number from you folks. it does indeed say active
@LancerLeads wrote:
Hey team,
@LancerLeads  - Welcome!
You can create a Self Serve account here, to check your status:
https://selfserve.publicmobile.ca/self-registration/
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
*Check if your phone is blacklisted (just to be safe) here: https://www.devicecheck.ca/check-status-device-canada/
@LancerLeads   just to clarify, you gone thought the Activation portal yourself? or the Walmart agent helped ?
If so, are you able to logon PM's My Account/Self Serve?
