Data not working
fwatters1988
I started my subscription with public mobile last week and transferred my number over from Koodo. I can text and call and my wifi is working but I cannot use my mobile data when not on wifi. How do i fix this? I have 3GB data on my plan.
CSA_PM
Customer Support Agent
Hello @ fwatters1988,
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
fwatters1988
None of the below ideas have worked, any more ideas please? Am I able to call public mobile for help?
hi @fwatters1988
To reset network settings, find the reset option within your device's Settings menu. For Android and Samsung devices, go to Settings > System > Advanced > Reset options or Settings > General management > Reset > Reset network settings.
To reset network settings on an Android device, go to Settings > System > Reset options > Reset network settings (or Reset Wi-Fi, mobile & Bluetooth) and tap the RESET SETTINGS button to confirm.
fwatters1988
Yes i have restarted, how do I do a network reset please?
hairbag1
@fwatters1988
have you restarted your cell ?
Try a network re-set to see if that helps.
