Help
Gwen322
I need to find out my public mobile account number but I forgot the initial email I had used. Every time I try to log in it says that I can’t. Is there a way I can find out my account number through a prompt or something
darlicious
@Gwen322
Put Public Mobile in the search box of your emails and look for your welcome email from public mobile. Embedded in the "Sent to" portion of the email will be your pm account number.
@Gwen322   is your service still active?  you need to have an active service before you can port out
did you try to use Forgot Password link there and try to enter all your email addresses and see which one get the PM email in the end?
Of course, if still unable to reset it that way, you can open ticket with PM Support :
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
RossN
i if you forgot your email or pasword and password reset doesn't work ,you  need to contact a customer service agent to help reset
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
