Help
Danielapage
I switched over to Public last night and my phone isn’t working fully. I think it has to do with the SIM but it says it doesn’t work when I try to add the eSim ? Help!
2 REPLIES 2
@Danielapage
Are you using a SIM or eSIM?
Did you reply to the text from your previous carrier confirming that you are porting over to PM with YES?
There is a 90 minute window for you to reply or porting will be cancelled or put in limbo.
If this is the case, you need to contact a CS_Agent by private messaging to restart the porting process for you. They can be contacted at:
If you did reply to the text, there could be a provisional issue with your SIM or if you subscribe with eSIM. Just private message a CS_Agent.
@Danielapage  First try testing network settings and reboot the phone if no luck please submit ticket with support to help you
private message   To CS_Agents click
