08-27-2018 11:06 AM - edited 01-05-2022 12:41 AM
Bought a SIM from Walmart
paid for a plan there so I assume it's activated.
Triple checked with bell that my phone is unlocked.
have reset my phone four times.
i have a iPhone SE
just get no service
is there something I need to do?
or is this SIM just bad?
08-28-2018 02:12 PM - edited 08-29-2018 05:36 PM
With the sim inserted in the phone, were you able to get through the activation screens? If yes, are you able to see your phone number under settings, phone?
08-27-2018 12:15 PM
Hopefully this gets sorted out for you asap OP.
08-27-2018 11:45 AM
@Abbysemojis wrote:How do I reach the moderator
You send a private message to Moderator_Team.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Help/ta-p/251745
08-27-2018 11:38 AM
08-27-2018 11:34 AM
@Abbysemojis Try the sim in any other phone and see if it works. You are not alone. I have seen a few more reports regarding exact same thing. Not sure the issue is on Walmart's end or public mobiles end.
Anyways, most likely you will need to reach out to the mod team via private message and they will look into your account.
08-27-2018 11:24 AM
I should mention that I factory reset my phone two times.
i removed the SIM so many times and I followed all of apples protocol....
08-27-2018 11:22 AM
i would recommand you to factory reset the iphone.
i am not sure why, but most of the iphone has problems with reading simcard.
08-27-2018 11:16 AM - edited 08-27-2018 11:17 AM
08-27-2018 11:14 AM
Have you tried removing the SIM and re-inserting or checking for a carrier update?
