12-13-2021 04:54 PM - edited 01-04-2022 04:57 AM
Opened my new PM account this morning, specified porting an existing number from Speakout, entered all the required information, waited for a text from Speakout to approve the port-out.
5 hours later I get a text from PM saying "We're having trouble transferring your number, looks like the information collected was incorrect". The information I provided is complete and correct, and my Speakout account is active and in good standing, Speakout SIM active in my phone right now. I got nothing from Speakout.
PM doesn't seem to have a support phone number (at least Speakout had that!), or live chat. I went through the lengthy and repetitive process to submit a trouble ticket online, hoping it went through (do I have an existing PM phone number? Who knows?).
So now what? Do I wait an unknown length of time for PM to contact me? Do I call Speakout and try to find out why they have an unknown problem? Are there any known problems with Speakout-to-PM I could address?
We're not off to a good start here PM.
12-13-2021 04:57 PM
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck and your welcome to Public Mobile
you will be very happy...with a Fabulous Service.
12-13-2021 04:56 PM
@IanM1 Try reading this thread by another customer who recently ported from Speak Out:
12-13-2021 04:57 PM
12-13-2021 05:07 PM
@IanM1 - yes, rough start.
Check your private messages in your Community INBOX. I sent you the Telus Porting phone number where you can talk to someone about your port.
12-13-2021 05:23 PM
@IanM1 porting from SO require a little bit more work. Create another ticket with CSA and provide the phone number to be ported, IMEI of the phone currently using SO , SO PIN#.
You can open a ticket using chatbot. But I suggest you to call the porting team(number given by @esjliv ) first to see if you can just give them the information on the phone, quicker that way
12-13-2021 05:44 PM
It seems that your porting is not completed so your Speakout SIM is still active and you can use for now until the porting is completed.
Meanwhile, the CS Agent will have to complete the porting process for you.
12-13-2021 07:30 PM - edited 12-13-2021 07:32 PM
Thanks for the suggestions everyone. Someone gave me an actual phone number for the Telus porting team, and they were able to help me right away.
New issue though:
I now have a text from Speakout saying there is a porting request for my number, and I should contact them if I did not initiate it. No suggestion I should do anything if the port is ok.
The porting team told me I should text back "Yes" when I get the porting confirmation request from Speakout.
Which is it? Do I take Speakout's message as telling me to do nothing? If so, how long will they wait?
Or should I follow the porting team's instruction and text back "Yes", even though no reply is called for to Speakout's text?
12-13-2021 07:39 PM
@IanM1 wrote:Thanks for the suggestions everyone. Someone gave me an actual phone number for the Telus porting team, and they were able to help me right away.
New issue though:
@IanM1 - Oh, good, well is sounds like the Telus Porting phone number I sent you got the porting process started again.
BUT - that is a bit conflicting isn't it? Gesh!
That is what the TEXT says, do contact if you did not initiate the port? Yeah, usually is it a YES to approve the port. Well, I guess, do not respond back.
But, I would keep the porting phone number handy to check in with them in a few hours to see if the port completed successfully...WELL, if you start getting incoming calls to your Public Mobile SIM card that is usually the indication the port completed.
12-13-2021 07:47 PM
Make sure the old SIM card in your phone when you're Transfer your number. You should get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
if you did reply: YES and you still stuck with Transferring your old Phone Number and
you need go to my OP instruction how to Customer Support Agent..
12-13-2021 10:16 PM
All good now, porting seems to have been successful. In the end I did text back YES to the Speakout message, but I'm not sure if that was necessary or not.
