01-05-2026
10:33 AM
01-06-2026
12:06 AM
computergeek541
hello,
I'm trying to reset my security login contact number as the porting process wasn't successful. How can I reset my login or sim card credentials?
01-05-2026 10:54 AM
01-05-2026 10:51 AM
hi @JMP80 so the port was not done and you want to restart the port process? or you want a new number now?
either wayz ask PM agent to help.
you can submit by direct message:
