10-02-2023 10:11 AM
Am I able to use my Public Mobile phone service in 2 countries without buying a SIM card for Mexico? I have been paying paying for 2 plans.
10-02-2023 11:27 AM
for use while in Mexico, consider getting a Telcel sim and a 30 day talk/text & 3GB data plan for about $16 Cdn. The crazy part is...that plan also works while you're in Canada, US and Mx.
10-02-2023 10:18 AM
Sadly Mexico isn't part of the roaming package. I'd suggest using a VOIP app like TextNow. Use a Mexican data SIM or WiFi to use it. Worth looking into .
10-02-2023 10:13 AM - edited 10-02-2023 10:18 AM
Unfortunately, Public mobile doe not offer roaming in Mexico and other international roaming (except for USA).
Some companies do offer a Canada-US-Mexico plan. Might want to check them out (ie. Freedom).
10-02-2023 10:12 AM - edited 10-02-2023 10:13 AM
Unfortunately not! Public Mobile only works in Canada and the US (with a roaming add-on or Can/US plan).
You will have to get a local prepaid sim, travel eSIM, or look at options from other carriers that are now offering Can-US-Mexico plans.
