10-02-2023 10:05 AM
soon as I login says continue activation
I enter same email and password but eversoft says it wrong.
I reset password still doesn't work
email is valid as I got my notice of payment received.
any help would be great as sim doesn't have a number yet
10-02-2023 11:17 AM
If still no email, of course check your junk folder. Sometimes the enail takes forever or you just have to resend n it
10-02-2023 10:08 AM
You will need to download the app and continue the activation from there. The desktop site will only let you go so far and then you enter the login loop that you are experiencing.
10-02-2023 10:08 AM
wait an hour and try using Incgonito mode to login
also, before login, make sure the province setting is collectly set and same as your plan province
