4 hours ago
I'm a senior with arthritis mobility problems. When my cell phone rings I can't answer fast enough and the call goes to voicemail. Rings are already set at 30 seconds/6 rings. I never use my cell phone to make or receive phone calls. I'm 'housebound' so always use my landline.
The only calls I get on the cell phone are delivery people buzzing from the lobby. I can't move fast enough to answer the cell phone before it goes to voicemail. I missed a deliver due to this!
How can I set up more than 6 rings, (8 to 10 perfect) OR completely remove or disable the Voicemail?
2m ago
Hi - Checked voice mail options but can not seem to find the number of rings option. Where can I find this option?
3 hours ago
you cannot set more than 30 seconds of ring and neither completely disable voicemail
however maybe you can set conditional forwarding when no reply to your landline
to enable: dial * 61 * + ten-digit phone number + '#' + SEND
to disable: dial # 61 # , then SEND
https://www.publicmobile.ca/en/ab/get-help/articles/call-forwarding
