01-08-2022 12:11 PM - last edited on 01-08-2022 05:40 PM by Dunkman
Hey I just ordered a refurbished phone through public mobile it arrived yesterday but the charger on it doesn't work so i'd like to return it.
However
When I go to fill out a ticket, it states that I cannot submit the form until all boxes have been completed, but the form will not let me check all the boxes.
For example it asks if I would like to Return or Exchange, I select 'Return'
I then go to the question confirming my return address to send the mailer, and it asks me a Yes or No answer.
I select 'Yes'
But once I do that it deselects 'Return' from the previous question, thus meaning I am unable to fully complete the Ticket.
Thank you for any one who can help me with this, hoping to get it sorted before my 30 days return period is up!
01-08-2022 12:54 PM
Perfect @leokerrigan you're one step ahead of me!
Hope you get this resolved ASAP - please keep us posted on the progress here.
01-08-2022 12:50 PM
I have thank you, contacted an agent and posted in the community at the same time!
Thanks again for the support
01-08-2022 12:49 PM
@leokerriganOnce again, I'd encourage you to get in touch with an agent by sending a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
01-08-2022 12:47 PM
It's not access the Ticket which is the problem, once I'm trying to fill that ticket out, that's where the issues arise
01-08-2022 12:31 PM - edited 01-08-2022 12:32 PM
HI @leokerrigan
Yes, open ticket with Chatbot will likely get quicker reply. Follow this exact steps and and it will help you to open the ticket:
- Type CPO phone
- Click Return or Exchange a certfied pre-owned phone
- Click Contact Us
- Click Click here to submit a ticket
- you will then direct to another page to open ticket.
01-08-2022 12:29 PM
You'd need to get in touch with an agent by sending a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
