03-24-2024 10:08 AM
Hello yesterday I transferred two number from Koodo. One worked and one is stuck. Still get service on Koodo but no texts, just phone and data. Got the text from Public saying port is good to restart phone but obviously not working. Have tried filling out a ticket but it keeps failing. Any ideas on next steps?
03-24-2024 01:33 PM
sent to your Community inbox here
03-24-2024
01:19 PM
03-24-2024
01:31 PM
ok Thanks
Update by Softech: email address removed
03-24-2024 12:31 PM
Says SOS only. Put Koodo in get data and calls but no texts. Called in was told port was complete but something is wrong obviously since it is not. Otherwise Koodo sim would not work and public would.
03-24-2024 11:50 AM
I am having the same issues. Can you send me the number too?
03-24-2024 10:42 AM
ys
03-24-2024 10:41 AM
ok
03-24-2024 10:12 AM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
03-24-2024 10:11 AM
@DAdam I will send you another message to call to sort it out. Might have to initiate again.
03-24-2024 10:10 AM
What happens when you put the PM SIM card in the phone? What about text, talk and data?
Are you able to receive calls or texts with PM SIM card?
