Friends referral code applied to my account or not?
11-22-2024
01:59 PM
11-22-2024
09:01 PM
computergeek541
Hi,
I signed up via a link my friend sent to me and I'd like to find out whether the code has been applied to the account so that we both get the $10 bonus credit applied.
Kind Regards
Payment
11-22-2024 09:00 PM
@MadPianist wrote:Both people get the credit.
That's not correct. Only the new customers who just got referred gets a $10 credit.
11-22-2024 02:38 PM
Sounds good, I sent them a message. Thanks
11-22-2024 02:36 PM - edited 11-22-2024 02:37 PM
not late. If anything and you don't see the $10 on your account after 72 hours, ask PM and they will honour it still
11-22-2024 02:34 PM
So it turns out she sent me two links and the one I used didn't have her code. So I do need customer support to add it.
11-22-2024 02:21 PM
@MadPianist wrote:Thanks, that's helpful. I mainly want to confirm if the code was passed through with my activation at all.
your friend can log in to their acct / Rewards to see if the got the point. (they will also get a message from PM that acknowledges your activation...Cha-Ching ) Also, you will see the $10 applied as credit to your account within 72 hours of successful activation using the referal code.
11-22-2024 02:12 PM
instead of use the link, safer to type in the code. There is a friend referral box on Payment step. Enter the code there and it is good enough. and sorry, no other confirmation. But you will see the $10 in 72 hours on My Account. If not, just an easy process to ask PM to add it back
11-22-2024 02:06 PM
Thanks but I just clicked a link she sent, I didn't bring up a panel to type in a code manually. I was hoping that somewhere I would see an indication that I'd used a referral during sign up.
11-22-2024 02:04 PM
@MadPianist .it should show up with in 72 hours after activation if it’s been more then 3. Days contact support to ensure it’s been applied correctly . If you entered it here you should be good
if you didn’t see that box and it’s more then 3 days here’s how to get support to help
11-22-2024 02:04 PM
11-22-2024 02:03 PM
It can take up to 3 days/72hrs and you will then see it as "available funds" in your account, those funds will be used first before any payment on file.
11-22-2024 02:03 PM
11-22-2024 02:02 PM - edited 11-22-2024 02:12 PM
@MadPianist wrote:Hi,
Kind Regards
Only your friend who referred you will get the $10 credit applied to his/her/it's account. Have them log in to their account to see if the $10 is showing as credited.
added...my mistake...the new customer will get the $10 credit while the person referring will get points only.
clipped from PM Help Files...https://www.publicmobile.ca/en/bc/get-help/articles/refer-a-friend
11-22-2024 02:02 PM
check back My Account in 72 hours, it will show as Available funds on your My Account
11-22-2024 02:01 PM
HI @MadPianist
the $10 is a credit and will be added to your My Account within 72 hours. The credit can be used on next renewal
