02-11-2022 03:03 PM
02-11-2022 06:27 PM
Only PM agent can help you with account issues.
If ticketing does not work, send them direct private mail as per links provided.
02-11-2022 03:34 PM
get in touch with Customer Support Agent (publicmobile.ca)
will reset.
02-11-2022 03:09 PM
Only the CS_Agent can help you with login to your Self Serve account but they will need your security PIN, email address, phone number etc.
02-11-2022 03:06 PM - edited 02-11-2022 03:08 PM
@Susiesikuliaq wrote:I need help to get into my self serve
@Susiesikuliaq ask customer support to help if you cannot use the forgot your password option.
Two ways to contact CSA:
1- Put in a ticket through SIMon Bot (usually faster method to get in contact with the Public Mobile Customer Support) by clicking on the bottom, right chat bubble.
OR
2- Private message the Customer Support here (slower method): https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
EDIT: sorry, I should have asked...was an account ever created? If not, you can register for one here: https://selfserve.publicmobile.ca/self-registration/
Also note, any account in nonpay/suspended status for over 90 days is permanently closed (including access to self serve).
