09-05-2019 12:08 AM - edited 01-05-2022 06:52 AM
09-05-2019 05:56 AM
Your best solution is to create a support ticket. Explain your issue to SIMON, the ? comment box in the bottom right.Answer his questions until you get to here:
Submit your ticket with the link at the bottom.
If that doesn't work for you:
Contact @Moderator_Team
It can take up to 48 hours for the team to respond to your concerns. It's best to create a support ticket as issues sent through SIMON are being given priority.
09-05-2019 12:16 AM - edited 09-05-2019 12:21 AM
Have you forgot your email address used to login to your self-serve account?
After activation, you should received a PM welcome email.
If you did not receive any email from PM, there may be a typo on your email address. Create a support ticket to ask moderator help. Click the ? icon at the lower right hand corner to get started.
09-05-2019 12:13 AM
You should have received an email when you first activated. Maybe check your various email accounts.
Have you tried resetting your password.
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
If not working, you will need to contact moderator. Expect 1-2 day wait.
Send a private message to moderator through the following link :
