Forbidden A1
loamyg
I recently switched over the public mobile. When I got to the transfer number page, it failed to move my number and I can't login on the Public Mobile App. When I try to use the website to log in, it redirects me to "Forbidden A1" on the page. I checked with my credit card, and the transaction went through.
What's the problem?
Babitjulka
I am haveing same issue
I port from virgin
loamyg
Nope, doesn't work when I refresh.
will13am
@loamyg, I get the forbidden A1 message all the time.  Simply hit the refresh button and everything will load.
@loamyg something you need to check with PM support
please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
