02-07-2025
01:50 AM
02-07-2025
10:37 AM
computergeek541
Yes I am also facing same issue , not able to login on account and there is no network showing in my mobile
02-07-2025 10:36 AM
02-07-2025 10:21 AM
@CS_Agent pls check here
02-07-2025 08:23 AM - edited 02-07-2025 08:23 AM
hi @Akashg
if you call from another phone to 1-855-4PUBLIC and enter your phone number, does the system says your service still active? or suspended?
if it says active, then try your sim card in another phone if possible
if same, ask PM support to check, you can submit ticket by direct message:
02-07-2025 08:19 AM
Hi @BKNS27 network still down , have restarted my phone severaytime, any suggestions please
02-07-2025 04:37 AM - edited 02-07-2025 04:38 AM
02-07-2025 02:00 AM
Same here no network in mobile, not able to call anyone
02-07-2025 01:56 AM
This is one of the major issues of Public Mobile. I need to pay my account and you have no way to do it. you cant log in, you cant call 611 cuz its dead air, the app doesnt work. So fustrating
02-07-2025 01:51 AM
Hi @BKNS27 are you getting you network in your mobile
