06-27-2023 06:51 AM
Anyone tried using EverSafe with iPhone 6...? I can login using EverSafe from newer Apple devices but not iPhone because the phone browser just goes blank wherever it loads EverSafe...
07-23-2023 08:48 AM
you said the app works on other iPhone, so you have another one?
you can use that other iPhone to help the activation process instead
On that other iPhone, make sure you logout the PM app, and go to the default browser , Safari I guess, and clear browser cache first
07-23-2023 08:21 AM
@kobeLou Have you contacted support to help you regain access
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
07-23-2023 08:16 AM
I bought in store the SIM card, I just can't sign in to complete the activation on my phone cause of the ever safe.id never opens, of course i prepaid my plan but cant have a phone line
07-23-2023 08:01 AM - edited 07-23-2023 08:01 AM
@kobeLou Are you trying to download eSIM to your iPhone 6 ? If so that’s the issue I believe I phone 6 only use physical SIM card . To use eSIM with iPhone it needs to be iPhone XS or latter
07-23-2023 07:33 AM
Yeah no app support for older devices it seems...EverSafe is annoying to me and not worth the trouble for it's extra security...
07-22-2023 10:16 AM
yes, you have to have support to link your new sim card to your account, please message them here
07-22-2023 10:12 AM
I bought at the Telus store my SIM card yesterday, I loaded the app on APP store, when I click sign in I just can't pass by the Eversafe page doesn't load, I cant activate my phone.
07-22-2023 09:00 AM
@kobeLou iPhone 6 does not have eSIM support, it only takes physical sim
So, if yours is really an iPhone 6, you will need to buy a physical sim card from local Telus/Koodo/Mobile Klinik stores or Amazon, then open ticket with PM support and ask them to help to change it back to physical sim card and add the sim card number onto your account
To open ticket with support after you got the physical sim card
07-22-2023 07:38 AM
Yes ! it is stuck at this activation page not loading I have iPhone 6, I paid my plan on my laptop scanned the Q code to get the app once I click on activate or sign in goes to a blank page ,Eversafe.id Telus. can't use my phone but paid for the plan, now I want to cancel but I can't access my account wow great start with Public mobile and no direct support phone or store.
06-27-2023 07:45 PM
I'll try that too and report back...so far I've used Safari and DuckDuckGo browsers...
06-27-2023 07:44 PM
No I haven't yet but I'll try it tonight and report back to see if that works thank you I didn't think of trying that...
06-27-2023 07:17 AM
@TheGx Have you tried on the new App with your iPhone 6 does that make any difference for you
06-27-2023 07:17 AM
@TheGx it could be a Safari issue, the app calls the default browser on the back to login
Can you download chrome and make it default and test again?
